The Protocol RIB Abstraction Layer has failed to allocate resources for a Adj-RIB-In or Adj-RIB-Out. The BGP session will fail to start. An attempt will be made to restart the session later.
This is an internal condition needing technical assistance. Contact technical support with the output of "show tech".
Error
The Protocol RIB Abstraction Layer has failed to allocate resources for an Adj-RIB-In or Adj-RIB-Out. VR = %p1% Session type = %p2% AFI = %p3% SAFI = %p4%
Name | Type |
p1 | uInt32 |
p2 | uInt8 |
p3 | uInt16 |
p4 | uInt8 |
